Maybe a repeat but what the heck - The factory rear muffler is just two straight pipes, perforated with glass fiber packing in the oval body. They are not necked down or baffled. I know, I cut one open. While replacing with straight pipes will change the sound tone and volume (and add drone, crossover or no), it will not add any real power given the lack of restriction in the OEM muffler. The images above of the straight pipes versus the OEM muffler were mine (it was a Snake Oyl unit). After getting tired of the drone, I made my own by cutting out the muffler of a donor unit and connecting the two pipes with a crossover. After tiring of that, (less but still had rpm specific drone) went for a used 2.5" Corsa (when everyone was upgrading to the 3" version), ceramic coated it and did the tip swap to maintain an OEM-like external appearance.
The factory tips can easily be removed, the dull ceramic coating buffed off and then chromed for about $45. Tack weld back on and you're good to go assuming you like the style and are just disappointed by the OEM dull finish.
With it, smooth tubes and Fram paper airfilters and no other mods, 435RWHP. Many years later, still find it to suit my taste (and budget).
