difference between gen 1 AND 2 BLOCKS ?????????????
MIKE-HKS
MIAMI FLORIDA
i need to know the difference between the gen 1 and 2 blocks
i need a block for a 2000 gts
i purchased a 93 complete motor to use the block turns out the front of the block is missing some cooling holes
the dodge dealer said it was the same block from 93to2004 ???????????
help
Ulysses
San Diego, CA. USA
If it helps any,
92-93 short block assembly part # 5245-687
94 short block assembly part # 5245-750
95 short block assembly part # 5245-967
96 short block assembly part # 4848-015
97 short block assembly part # 4763-703
98 short block assembly part # 4763-703AB
99 short block assembly part # 4763-703AD
00 short block assembly part # 4763-703AD
So it appears that there have been some changes. And 2002 was the last of the genII.
Dyno Dave
Davisburg, MI 48350, USA
The Gen 1 has removable wet cylinder liners (known as the "heavy-weight" engine). Gen 2 started in '96 and I believe were only installed in coupes and the roadsters still getting the heavy-weight until '97.
Correct me if I'm wrong please.
Tom F&L GoR
Wappingers Falls
Gen 1 thermostat is in a housing with feet that look like small intake runners at the back of the block. It has steel tubes that run along the sides of the block that I didn't think Gen 2 had. Gen 2 thermostat housing attaches in the valley at the front of the block. Cannot be the same block. I think you've been hosed.
tbone96
