Door opens by itself
AlvaSpeed
Panama
I shut the drivers door and it pops open.
Like you were oppening the door from outside.
I did a search and I could not find anything.
Copernicus
MD
I think the first area to investigate would be the door harness. It seems that is one of the weakest points in these cars.
GTSnake
Motor City
Yup, door wires. Same thing happened to me. I believe it's the blue with red stripe wire.
ByteMe
Kirkland, Washington
If that is not it, my problem was the microswitch for the door open button. The door would open by itself or when it did close I could do a "Fonzy" by hitting it lightly at the bottom and it would open.
nismobrown
wales, GB
yes and no as the micro switch is operated by the external button.
to confirm it is the switch, listen up close as you press the door button and you should hear or feel the quiet click of the switch operating. compare the noise and feel to the other door and see if there is a difference. if one clicks and the offending door doesn't then i would say that it is the switch.
to locate it , remove the door card and the interior plastic trim at the rear of the door button. watch you don't damage the thin rubber sealing tape which is at the top of this trim . you might be able to repair it if it has no corrosion but it's more likely to be scrap. the switch is held in place with a small plastic retaining pin so make sure you don't lose or break it .
all the best, dave.
vipah
San Diego, CA
Does anyone have any pictures of how to remove the switch, or panel to view the switch?
I don't want to damage anything.
GreatWhiteKAC
