Door popper's for 1995 Viper
Bull Valley IL USA
Door popper\'s for 1995 Viper
I had a Clifford 40 alarm placed at an aftermarket alarm company last year and they were able to use the door popper silonoid on the drivers side, but said the passenger side was either not working or missing. I called the local dealership this year and they are not sure of what part I am talking about. Could someone either give me the accurate part name or part number that I need? The alarm company said that once this part is installed the door popper will be functional.
Has anyone else delt with this issue?
Thanks,
John
RonC
Tucson Arizona
Re: Door popper\'s for 1995 Viper
If your missing a solenoid, and considering its a Venom 550, Hennessy probably took it out and sold it...He seems to do those kind of things your know.
Just kidding...well not really. Go here: http://www.viperclub.org/menus/index_how_illup.htm
Ron
ruckdr
Renton, WA USA
John,
It sounds like the Clifford alarm system will send a +12V signal to activate the AFTER MARKET installed door pop solenoid(s). It is possible that only the drivers door was fitted with the solenoid. If you go to the "How-to", then "Illustrated Upgrades" and open the instructions for "door solenoids", http://www.viperclub.org/menus/index_how_illup.htm
you will see the solenoid after market part, and where to get it.
You might want to take the door panel off to see if it is there and just not connected (a lot of work, I know).
Later,
Qdog
