Drivers door doesn't unlock with remote
Greg D
Drivers door doesn\'t unlock with remote
Hello
My 97 GTS drivers door no longer unlocks with the remote. (the passengers side works fine. (I noticed the light in the rocker switch doesn't light up either on the drivers side. Passenger's side lights up fine) I have to use the emergency lever to open the drivers door and with the window up I can't get to the emergency lever!
Any ideas?
Qualitywires.com
Louisville, KY
Re: Drivers door doesn\'t unlock with remote
try synco your FOB's by holding both buttons down at the same time until you hear your horn honk to confirm. I upgraded my FOB's with the newer ones and they seem to work well.
Rich Carlson
N. Richland Hills, Tx
When you say "remote" do you mean the outside electric switch????
With the window up, unlock the hatch and reach around the pillar to release the emergency lever.
MES
Sarasota, Florida
Sounds like an electrical problem, open circuit. Also you can easily open the drivers door by lifting the rear hatch, then reaching inside for the emergency exit
Afy
homeless in hell
It is probably one of two things.. either a microswitch failure.. or a break in the wiring.
I had the same problem and it turned out to be a wiring problem..
Matt M PA
Langhorne, PA USA
I'm with Afy. My 2000 GTS had the driver's door speakers stop working. The wires had broken clean inside the rubber boot that goes between the door and door jamb. I would check there first. I had to edit this post to add that it was one speaker wire and another wire that had something to do with the door latch. But, both had broken clean. We made up some short lines so that the splices would not be inside the boot anymore, but inside the car.
Y2K5SRT
Overland Park, KS
Interesting on the wiring. They ordered a new door switch for my driver's door a couple weeks ago. Hopefully it will get in this week. My deal was that it would not open from the inside, but the outside switch worked fine. Been using the "emergency" release on the driver's side to get out for now. I also noticed that when I stop the car it isn't always "releasing" the locks (either side) now. Hopefully the switch has something to do with it. We shall see...
Chris
