Easiest way to disable interior lighting
KenH
Portland, OR, USA
Just curious if anyone knows an easy way to disable the interior lighting so that doors and the hatch can be left open for extended periods of time without killing the battery. Is there a convenient fuse?
prodiver
Apache Junction AZ
Open the doors then close the latch with them open. Doors won't close until you open the latch again but interior lights will be off.
Silver Snake
San Diego, CA
Yes there is a fuse, but it also kills the radio. Not sure if you are looking to permanently disable the lighting, but I always pull the fuse if I am going to have the doors open for an extended period of time. Sorry I can't recall the particular fuse, but if this is the solution you are looking for I can go check.
Also, if you don't want the lights at all then it seem like you could just remove the bulbs, right?
SKY1960
