Eastern catalytic converters
Daxzz
Anybody know anything about these? They are a single cat set-up (per side), as opposed to the stock dual cat set-up, with the flex joint and they supposedly flow better than stock. I can get a pair pretty cheap but I don't know whether or not they'd be an improvement or if I should go with one of the other high flow options. Any input is appreciated. And before someone says it, yes, I already tried multiple search variants without any results.
D
Daxzz
Thanks for the input, Wiretech. The Roe's and the Random Tech's were the other options I was considering. Still wondering how the Eastern's compare, in terms of flow rate, to the other options available.
Wiretech
Toronto Ont
Stocks cats has 400 cells per sq inch as eastern cats has 200 cells per sq inch same as roe's cats. I just order a set of eastern last week, I still have to install them Ill let you know how it goes.
funkykilla
San Francisco CA
Hey guys,
I actually need a set of stock cats to register my car in California (it came without cats). I can't use eastern as they aren't legal here. Does anyone have a set of OEM cats they'd be willing to part with for a price? Please help, already got a ticket for not registering.
eucharistos
Houston
mattsmusic
Boston MA
I have a pair of stock 06's. The driver's side needs help but the passenger side is perfect. Let me know if you're interested in them.
CA97GTS
Riverside, Ca.
Hey guys,
My Random Tech hi flow cats passed easy here in CA. 97 GTS
Paul Hawker
San Diego, Calif, USA
Just a warning, that earlier Vipers could pass emissions with just a single cat when new, but as the miles accumulated they began to flunk the tests.
funkykilla
San Francisco CA
Hey guys,
Just got a set fro X2, sorry bout posting a request in the wrong section. Its an 06 supercharged, hoping that doesn't mess things up for me too.
Viper X
You may be able to pass the sniffer but you won't be able to pass the "visual" with a supercharger unless ......
Sonoman
Sonoma Cownty
Aftermarket engine parts have to be approved to pass smog in CA and other states. They will have a number on them that can be checked in the certified parts records by the smog tech. For instance, my buddy's Mustang has a Vortech supercharger that is approved for his model year, gets flagged on the visual part of the smog test, then checks out OK due to the certified EO number.
Viper X
Paxton does not have approval or and "EO" number in CA.
