genXgts
Just came in from a 4 corner EBC Green install on my 97 GTS.
Like most things Viper I go in with a little hesitation and come out wishing I would quit thinking about the value of the car and just do all the work myself.
Notes of interest: Rotors pop off the car with no trouble at all, fronts require 3 bolts, 2 on the caliper and one holding the brake line to pull off the caliper. Then the rotor is easily removed and sanded off the car. Much easier for the 2 minutes it takes to pull the caliper. Front brake pistons can be manually flushed up into the caliper with muscle power alone (make sure to crack the cap off the underhood resovoir).
Rears are even easier, after taking the retaining pin and squeal spring out the pads literally fall out with a little persuading, and the rotor sneaks out as well, with the caliper still attached.
With no "special tool" within 500 miles of my location, I opted for the needle nose with tape for safety. Not a problem at all, truly a 60 second operation. Spent more time reading about the tool then improvising without it.
New pads pop right into place after scuffing the rotors good, put the spring back and pin and your good to go.
Total time to hit all 4 pads next time after the car is in the air:
30 minutes tops.
until next time,
30 minutes tops.
until next time,
