Eibach springs
Triple7
Melbourne, FL
I am shopping for my first Viper and am considering a 2000 GTS that has been lowered 1 inch using Eibach springs. How much of a problem is this going to be on the street? Thanks
Diablo Joe
Lakeland,Fl
No problem where I live.1 inch isnt what I thought it would be.If I ever buy coil overs,Ill try to go even lower(staying within alignment tolerances)My NSX is much lower.The front lip is 3.5 inches from the ground and the whole car is 43 inches from ground to roof.
Joe
jcaspar1
Sacramento, CA
Check and see what your stock height is. My stock 97 is only 4" to the lowest point of the front dam. When I put on Porsche deflectors an inch lower they didn't last long.
King GTS
Houston, Tx.
No problem at all. The springs will cosmetically change your Viper for the better. There's just way to much space between the wheel-well. I'll always have them or some sort of lowering spring.
ctrengine
