EL MIRAGE 1.3 mile speed Challenge in A/BGT
Svsi
West Chicago, IL, USA
Svsi is looking at going to EL MIRAGE. We did some testing with our stock bodied GTS-TTRS at Maxton, NC. Svsi ran 220 mph in A/BGT at the Maxton Mile.The A/BGT class at EL MiRAGE is open and has a minimum that you have to exceed 175 mph in 1.3 miles. SVSi has been teched in A/BGT and have our license to 250 mph+. No one has run this class at EL MIRAGE so it should not be to challenging to run 235 to 260 the first time out in 1.3 miles for a Twin Turbo stock bodied Viper.
futureacrowner
Hmmmm, thats fairly close for all us SoCal guys, we should head on up and spectate. Don't bring vipers though unless you like driving down 3 miles of dirt roads and what not.
futureacrowner
you gonna pull 6th gear with the stock 3.07 gear or are you gonna try to max out 5th gear with a 2.73 gear in the rear?
They blew 5th... 6th is mechanically a weaker gear than 5th. Logic tells me the car won't even have a T56 but likely a REAL tranny with a moderate OD and a much lower (numerically (that means numbers)) rear end gear.
There is a reason all the fast 1/4 mile cars gear them to only hit 4th, same principle applies here.
techanvi
