Electrical connectors
AJ02
Azle Tx.
Is it possible to buy just the electrical connectors that connect the radiator fan to the car's wiring harness on a 2002 GTS?? Mine are all corroded and somewhat melted. The fan will come on and run for just over a minute and then go off. Not good when it's 107 degrees ambient temperature. I know there are other connectors available, but would preferr to stay OEM if possible. Just in case something similar comes up in the future such as the fan dying. I could research on the web, but can't find a brand name on them. Bummer. Till I can get it repaired, I'm stuck in my 77 Vette with no A/C!!!!!!
jdeft1
Metropolis
Cut it off!.... Screw the OEM connector. I'd solder the wires direct then look for a proper connector.......
This, before I'd drive the vette.
dave6666
I saw the title of this thread, and was thinking I would post "Dan, at Viper Specialty"
Sooooooooooooooo, try contacting Dan at Viper Specialty.
LOL
PS - ask him about his custom wire harnesses ;)
potterb4
