ceokris
Gen II '97 GTS
Has anyone run Siemens Mototron 60# injectors? I've recently installed a forced induction system currently limited to 5psi. I know I need more fuel. Just seeing what other people run in the 5-8psi range.
Currently I'm looking at 60# injectors and fuel pump booster.
I already have splitsec and msd boost timing master. Is anything else 'required' to manage the fuel? I have the splitsec dialed in similar to what the stock map sensor provided, and configured 5.1 volts max to pcm during boost.
Thanks in advance.
Thanks in advance.
