fuel pump gen 1
hemi al
hello. what hp. will the stock gen 1 fuel pump support? is there a better pump for high hp? what hp. will the stock fuel line support? thanks, al
dansauto
gillett, pa, usa
stk fuel system will handle 600-625 pretty safe anymore than that and you are taking chances. Lots of methods to increase fuel for higher hp, adding a second pump in the tank is the easist.
H
hemi al
thanks for your reply. using a second pump would probably imply a larger diameter fuel line as well. the two pumps would be run into a common feed fuel line. is this correct? thanks, al
