SidewinderGTS
- Joined
- Nov 7, 2005
- Posts
- 275
- Reaction score
- 0
Whats the best way to take out the gas tank on a 97 GTS.
Thanks in advance
Thanks in advance
1. Locate nearest firearm.
2. Lock and load.
3. Insert business end in mouth.
4. Pull Trigger.
But in all seriousness, why do you need to remove the fuel tank? You will need to cut open the bulkhead panel and remove it through the trunk. It is a major headache and not for the faint of heart. If you need to replace your pump, clean the tank, etc... all of that can be done from the access panel under the carpet.
2. Lock and load.
4. Pull Trigger.
Replacing rear frame to much damage to pull.
His car is a GTS, which I've always heard is much easier than a RT/10. I'm scared to ask, but whats your process for RT/10 tank removal? Drinking ******?
Do you have to remove the roof panel and the rear tub as well? If so, then you will have no problem removing the fuel tank.
Roof panel No rear tub yes
