Gen 3 Service Manual Fluids Questions
slaughterj
I can't seem to locate my Gen 3 service manual. Can someone look up and post the capacities for all the fluids (brake, clutch, transmission, differential, antifreeze, oil, etc.) and the listed recommended frequencies for changing each of them (mileage and months)?
Wiretech
Toronto Ont
Brakes 7.5 oz Dot 4, Transmission 3.8L Sae-75w-85, Differential with addive 1.35L 75w-140 , Antifreez 15.1L ,Oil 10.4L Ow-40, Clutch Dot 4 1L, Power Steering Dot 4
slaughterj
Thanks, anybody able to post the mileage/months points at which to change each of the fluids, as stated by the Service Manual?
Wiretech
Toronto Ont
Engine oil should be 3 Months or 3000miles, rear axle 12000miles or 4 years. coolant 5 years or 100,000 miles. transmission 20,000miles or 4 years, brakes and clutch and coolant 60,000miles or 5 years, depends on your driving condition I would change the fluid more frequently hope this helps the manual has too much info
Garron
You should just look at the condition of the fluid. I find the clutch fluid turns black the fastest followed by the rear diff fluid
Garrett
Qdog
