Gen I Cylinder Head Torque
Jerry Dobson
Lenexa, Kansas
I was looking at my Gen I motor manual for Torque Specifications, it says:
Torque to 30ft pounds on the first round and then add 1/4 turn on the second. This does not sound correct. I was expecting 60 to 90 pounds total. Do all the manuals state this procedure?
XLR8
Mesa Arizona
That is called a torque to yeild spec. It is used on heavy equipment among other things. You should torque the head bolts to 110 ft lbs as the final torque. The manual I have says 90 ft lbs but that is not enough for a good seal. Do not lube the threads, install the bolts dry.
J
Jerry Dobson
Lenexa, Kansas
Steve-Indy,
Thanks for the link. This is more like it. Yes I am using the Multi-Layer gasket.
Jack B talks about replacing the head bolts. Any problems with re-using the head bolts?
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
Jerry,
Quick reminder - do not rotate the crank or yutn over the engine with the heads off as you risk breaking the seal on the Gen 1 wet cylinder liners.
Good luck with the change out of the gaskets.
