Gen II Brake & Clutch Bleed Questions
smashman
Colorado
Thanks in advance for answers....
1. What size hex head wrench is needed for the brake bleeder screws? Inside front, outside front, and rear? Did I read somewhere they are two different sizes?
2. What is the proper inside diameter tubing that will attach to the brake bleeders?
3. What size hex head wrench is needed for the clutch bleeder screw?
4. What is the proper inside diameter tubing that will attach to the clutch bleeder?
5. Is regular clear plastic tubing from Home Depot OK for this, or does it need to be silicone or something else so that the brake fluid won't eat through? I'd like to construct a "permanent" Brake Bleeder Bottle for this, as I plan on using the two-person method with cooperative wife or offspring assistant for all 3 of my vehicles.
Again, thanks in advance for info.
