Has anyone here had to repair a rear tire (nail hole etc..) ?
TAPROOT
INVERNESS IL
I have a nail twards the center of my rear dr side tire .Tire has 1,200 mi on it. I want to know if anyone here has been threw this? I have heard mixed opinions..some dont chance it and some say use the patch plug combo... What to do??
Ivan-
Kurt 97 GTS
Dallas, TX
I've had my rear tire patched before and have NOT had any problems!! It should not be an issue unless in/near the sidewall of the tire.....Kurt
TRAMP 13
Montgomery ,Al
I have had two flats both on back tires, told them to take tire off and put the patch on the inside .Never had one of my tires pluged.Keep a pump that work off of the cig.lighter ,air up tire and drove it to them .A lot easier than taking it off yourself.
Jake654321
Had a nail in middle or right rear. I use Discount Tire. Their equipment easily handles our size rims.
Fixed from inside, no plug. No problems.
T
TAPROOT
INVERNESS IL
I have seen the patch but never seen the patch plug combo.I am driving myself crazy with this problem.
Daffy
Ellicott City, MD
Tap,
I just had this a couple of weeks ago. Caught a nail in the rear passenger, dead center of tire. I keep a small cig air compressor for autox in the trunk, it saved me to get me home safe. Took the wheel off and up to a shop that handles split rim truck wheels, etc recommended by my viper service dealer, next day I put it back on & no worries yet. They patched it from the inside, they said no plugging on these tires. I've probably got a thousand miles and one autox on the tire now and, knock on wood, all's well.
Good luck.
Dave.
SoCal Rebell
Mission Hills, Ca USA
OK, here's the deal, have them put in the largest inside patch available. I've had patches put in my rear tire in both my first and second set of rear tires. I'm currently on my third set with no rear patch (thank god). I did not have any problems with them BUT when I road raced, that was all that was going through my mind when I was going around a sweeper at 125 mph. A patch voids the "Z" rating, if you can have it "vulcanized" this will retain the "Z" rating.
onerareviper
Pittsburgh, PA, USA
Had it done. No problems. The plug/patch combo is mearly a patch with a small plug on the center of the patch to help center the patch on the hole. Did that make sense? AS LONG AS IT IS NOT NEAR THE SIDEWALL, YOUR FINE. I talked with many experts before I felt confident to do this and drive fast without worry.... They all said the same thing - "Don't worry, as long as it's not near the sidewall".
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Patch it and dont worry.
Ive had more Viper flats than all other 100+ cars put together !
{Would I run a patched tire in an open road race? NOPE!
In a club event of 20-minute sessions? YUP! }
Ron Hickey
Falls Church, VA
I was in upstate NY in the middle of nowhere one summer and picked up not one, but two screws in a rear tire. The best repair I could get was to have the holes plugged. I was only able to put another 27,000 trouble-free miles on that tire before I finally swapped it out. By that time, the other rear tire had been patch/plugged. I replaced the tires before my first Viper Days event, since I didn't want to push my luck. I'm driving around now on a patch/plugged front tire. I don't plan to do any Viper Days or compete in a Silver State Classic on these tires -- just everyday driving.
I would avoid just plugging the tire, but I really wouldn't worry about the patch/plug combo for everyday driving.
Chuck 97 GTS
Tap, go to KO Tire in Elk Grove. I had them patch my rear tire over 2 years ago. It's a family run business and they will take good care of you and do the job right.
V10 MOJO
Youngstown, Ohio
BS! i disagree. drop the cash and get a new tire. i have been thru two complete sets and two additional tires for the front (i guess i just got bad luck and attract sharp metal objects to my tires) (of course my accelerator pedal had nothing to do with it). bottom line; patches are substandard and despite how minimal the chance of failure its there, and without the warrany or roadhazard or insurance of a new tire.
onerareviper
Pittsburgh, PA, USA
I guess if you got the excess cash, why bother with the patch/plug. Although, if you do get a new tire, you will have to replace the other side as well. All the experts told me different tread depths on left/right is a BAD idea. This means your out nearly $800 bucks after mounting/balancing. That's a lotta dough, considering a good patch/plug only cost me $25 including labor.
T
TAPROOT
INVERNESS IL
Did the patch plug combo. You guys are #1. The responses well needed! Thanks viper brothers!
Mpcc
