Has anyone installed 2003+ Intake on Gen II Motor
PowerKraus
Texas
I am new to the Viper community, and am curious if anyone has tried the 2003+ intake on a Gen II (i.e 2002 GTS) motor. It 'looks' like a vast improvement, and afterall, the increased HP on the '03+ is not solely from the increased cubes.
Seems this would be an easy bolt-on. Since I'm pulling mine to put in the lower 'stat, I figured an intake swap would be POC at this time.
.....as a newbie, I just looking for a few 'bolt-on' ponies.
Thanks guys....
opnwide
austin tx usa
gen III intake is more restrictive, designed to fit the lower hoodline. The gen III heads are a different story.
P
PowerKraus
Texas
Interesting, as it appears to be the same intake on the truck? Also with clearance issues? Anyway, the main body looks larger for a greater plenum volume, And this appears to have affected the individual runners....and like you say...perhaps in a negative manner.
Has anyone actually done testing? And the heads may be better eh? Do you know if they recast/modify the GEN II or is it more of a little clean up?
Heck, just asking, I may be very late on this topic, all you veterans may have already flogged this one to death.
Help !! <<SVS did it on the TTRS>>...man, that is freaking greek to this Viper Rookie. and the down low on the side baby...
Tom86ZT
chicago, IL
looked into this, you need a hood about 4 inches taller to make it fit. I believe svs is using a custom fabbed intake.
MoparMan
Las Vegas, NV
I heard that the gen II intake mated to a gen III engine makes more power and torque than a stock gen III engine because of the restrictive stock intake. Is this true?
SKY1960
