header gaskets fit for Belanger headers
jjp11
I have a 2001 RT/10. I ordered replacement header gaskets for my Belanger headers - part number 5004014aa from http://www.partswebsite.com/dcjparts/
I compared the gaskets together and noticed they do not match up perfectly in size. Did I order the wrong parts, or will they will fit?
ViperTony
You want to use the OEM metallic multi-layer gaskets not the fiber ones that come with the Belanger headers. In fact, you can reuse your original OEM metallic gaskets as they are fairly durable. The Belanger fiber gaskets tend to cause leaks over time, they ****. Stay away from them. Part# 05004014AA is the correct part number. The parts listings for are available in the How To Section: http://www.viperclub.org/downloads/2001_Viper_Parts_Listing.pdf
J
jjp11
Aren't those what I ordered though? The metal gasket in the top picture is on the left and is part number 5004014aa. The gasket with the wording on it is from Belanger. I just want to make sure the metal one I bought will fit, because it doesn't have the exact same shape as the Belanger provided gasket.
ViperTony
The metallic one you have is the correct one.
