Help with noise from rear when slowly accelerating from stop or slow tight turn?
CMilViper
Burleson, Tx
I have a noise that happens pretty consistently when slowlyin starting to roll from a stop, or when in a slow, tight radius turn.
It sounds like "click", and sounds like it is coming from the rear of the car.
Any ideas on what this could be, and/or how to fix?
Thanks!
ulllose
Brunswick, Ohio
Thanks!
Check the ebrake......while turn that tight radius pull up on the ebrake and see if the noise stops. My ebrake caliper froZe up and the inside pad wore down to metal and I would hear when turning tight or moving very slow. The car had 13k at the time
C
CMilViper
Burleson, Tx
Thanks ulllose. I will check out pulling up on the ebrake a little, and see if the noise still occurs.
hightest
sounds like possibly the diff clutches. Adding some mopar posi-traction additive will help if that is the case.
RTTTTed
Or search because there's quite a few threads on this.
Click? or click, click, click...
29OUTLAW
Solomons Island, Md.
I get the click about 25% of the time when taking off from a dead stop. Never when turning. Mine is not from the ebrake. I've drove for weeks with the ebrakes completely off the car while I was painting them. Still got the click. I have the Mopar posi track additive also.
I'm not too worried about it. I've had the click for years and it doesn't seem to cause any issues or get any worse. Might just be one of those thing where something has to literally fall off the car in order to find the problem.
techanvi
