How do I reduce my Vipers Weight
jp
Umea, Sweden.
I would like to do some serious Weight reduction (the Viper). Were do I start, Hood, crossmember, Bumper reinforcment???
The car is a RT/10 1995
Thanxs
Afy
homeless in hell
Get rid of the engine.. that will save a lot of weight..
(Sorry just couldnt help my self..)
Chuck 98 RT/10
tampa, fl USA
Another legitimate question that comes up once in a while. My first guess is to get a carbon fiber hood, doors, etc.
In my case, I need to loose about 50lbs around the belly.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jp:
Were do I start,...???
Thanxs
<HR></BLOCKQUOTE>
Switching to a Gen2 makes it real easy.
Hood. Save lots
Gen-2 tube headers save 26 lbs
Interior panels save 15 lbs.
Lighter wheels save rotating mass and weight
Lighter rotors save 7 lbs. Factor higher due rotational
Alum flywheel save 29 lbs ROTATONAL !
Mufflers / cats save 10-15 lbs to hi-flow
A/C removal saves 30+
Heater etc saves 10+
Plexi windshield saves 15???
Radio/amp/speakers saves 10
Are you in the 10s yet???
It's closer to one hundred than "a few." The suspension components are lighter - both wishbones and knuckles. Even the front hub bolts are hollowed out to save a few grams.
AviP
New Canaan, CT
Here's my weight reduction list.
Remove:
- A/C and all hoses/tubing/vents
- Radio and speakers
- Passenger seat assembly
- Spare tire
- Jack
- Power windows.
- Carpeting / floor mats
- Cigarette lighter
- Glove box
- Ash tray
I'm guessing 200 pounds saved.
Change to:
- Lighter wheels.
- Suspension components.
- Carbon fiber bodywork
Another 200 pounds perhaps?
This is an interesting exercise.
-Avi
J
jp
Umea, Sweden.
I have done the following in saving weight;
Headers
No cats (straight 3")
Alu Flywheel
Purner Wheels
No Spare
No speakers
No Stereo
Following is added in weight to meet NHRA rules;
Rollcage (modifed Bar)
Clutch and Flywheel shield
Loops for Drive shafts and the "main" shaft
The car now weights race ready 3673 Pounds (including Driver and Gas) (driver 158 Pounds)
So according to the above advices is this what easily can be done to save weight;
AC removal
Lighter Hood (Carbone fibre od Glas fibre)
Take away the reinforcement inside the Bumpers
Fabricate a front Aluminum Crossmember
Have I missed something?
Jon, yes I'm in the 10s now...still learning, and making progress, let you know soon. Pictures on www.venomusracing.com
Bob Woodhouse
Fort Worth, Tx.
jp: Big weight first: Stock hood and brackets weighs 87#s, fiberglas autoform is 27, kevlar is 12. Doors, remove completely, install aftermarket fiberglas by autoform, reasonable cost, saves about 40#s each. Reason, door beam gaurds etc. Use original aluminum hinge and latches.
Drop 20 lbs each with racing seats. That's 200lbs, what was the objective? Forget the little stuff, like crossmembers, too little gain. Want more? Let's talk brake rotors, but $ per pound is beginning to climb now.
J
jp
Umea, Sweden.
Wow Bob! Thanxs, this is great information, now do I sure know what will be done this winter...
