How much more power with a 10 psi Roe kit?
ERDOC
Raleigh, NC
My current setup gives me 532 rwhp/ 530 rqtq with heads, cam, exhaust etc....
How much more rwhp/rwtq can I expect with a 10 psi Roe kit? Has anyone with similar starting point as me put on a 10 psi kit? Do you have any dyno results? Thanks!
ChicagoGTS
Chicago, IL.
Depending on how radical you go on the heads, I would expect anywhere between 690HP/750TQ to 725HP/800TQ. You may want to wait for Sean's intercooler before you jump up to the 10lb pulley. I would say that you would probably net the the first figure if you started with the 8lb pulley.
~Matt~
DrewViperz
