How to power shift?
Mopar Boy
Ontario and Ohio
What is the correct way to power shift Vipers? My fathers style is to hammer it in and somewhat drop the clutch so the rear tires try to break loose (he is accustomed to the 60's muscle cars).
I on the other hand, was under the impression that it was better to slip the clutch a slight bit as it is easier on the driveline (no shockload) and it gives slightly better performance as the motor does not bog as much.
Who is correct? :dunno:
Thanks!
Robert
Dom426h
DE
u are correct. breaking the tires loose shifting to any gear yields in a higher ET i wouldnt worry if your just barely chirping though
shift fast and keep the power to the ground
slamming through the gears breaking the tires loose is for movies
...and showing off (i'll admit) :)
Cobraken
Southern Oregon
Definition of a power shift when I was growing up: Pedal to the floor, no clutch, yank and throw. Speed shift: Same as above but use the clutch.
FATHERFORD
Texas
Speed shifting as I know it is just shifting really fast.
Power shifting is not lifting your right foot off the go pedal, and just shifting and pressing the clutch extremely fast.
Power shifting knocks off maybe .1 off your 1/4 mile time. It's not worth it IMO.
Bobpantax
Miami
Power shifting is not lifting your right foot off the go pedal, and just shifting and pressing the clutch extremely fast. Power shifting knocks off maybe .1 off your 1/4 mile time. It's not worth it IMO.
Agreed but with one strong suggestion. Power shifting should not be done without a scatter shield. Back in the early sixties I remember seeing a young man, whose vehicle did not have a scatter shield, severely injure his legs when his clutch and flywheel let go on a power shift. It was not a pretty sight when they took him out of the car.
M
Mopar Boy
Ontario and Ohio
OK. My bad. It would appear that I am using the wrong term.:rolleyes: Thanks for the definition Walker and FATHERFORD.
Let me correct my previous question. What is the correct way to speedshift....:D ;)
Robert
revived_gearhead
Charlotte, NC
My suggestion is to avoid banging gears in the Viper. The old Muncie and Saganaw T-10 transmissions were able to handle the abuse to the shift forks. The Viper trans, as strong as it is, does not like to be banged between gears. I was told to shift the tranny as though the shifter was made of glass. Shift it like a road race car instead of drag car. I've abused plenty of T-10 and Muncie trans in my days, and know from experience, the T-56 doesn't like it.
SquadX
VA/MD/DC
From a stand still (more then once), I've taken the rpms up to 1500, dropped the cluth and spinned tires a couple times before getting any traction but the car still bogged.
Other time from a stand still, I took the rpms up to 2k slipped the cluth at about 18-1900 rpms and launch very well.
So I would say from my experience, which is limited, working the rpms up to a moderate rpm range then slipping the cluth to the point were you control the power and tire spin and once good traction is felt then drop. Action should take less then a second or quicker for better drivers. I am not saying this is right but its how I've launched well before so take it with a grain of salt.
SquadX
VA/MD/DC
Hey Revived gearhead, can you elaborate on "shift like a racecar". More detail please. I am still learning and dont want to drop 5k to replace my trans because of poor shifts.
revived_gearhead
Charlotte, NC
The old Muncie and T-10 transmissions in the early Camaros and Chevelles would stand up to shifting the gears while holding the throttle to the floor and forcefully yank the shifter into the next gear. You still needed to use the clutch, but never lifted the throttle. By shifting the Viper trans like a roadrace car, I mean lift the throttle and gently shift to the next gear. There's no need to bang the shifter into the next gear with the torque and HP of the Viper. There is no positive stop to prevent you from bending the shifting forks inside the transmission. Shift it like your shifter is made from a piece of crystal, and your trans will last a long time.
SKY1960
