How to remove hood pad clips (97 GTS)
Discussion in 'RT/10 and GTS Discussions' started by Bad_Byte, Apr 3, 2005.
  1. Bad_Byte
    Bad_Byte Viper Owner
    947
    Jan 16, 2002
    Riverside, Ca.
    I know it should be self evident and easy for the simplest of minds. That's where I fall short. I look for the complicated in everything.
    Do I just grab them by their little wings and yank?
    I'm referring to the clips that hold the hood pad to the hood. The little plastic thingys.
    Do I need to buy new ones before putting the pad back in place? If I do where can they be located?
    Thanks Mucho in advance
  2. FLX109
    FLX109 Viper Owner
    1,703
    Aug 19, 2002
    Massachusetts
    Grab them wings together and twist and pull. some come off clean others damaged, might be smart to purchase some from Chuck Tator.
    FLX109
  3. 1MEANSNAKE
    1MEANSNAKE Viper Owner
    922
    Feb 17, 2004
    Prince Frederick Maryland, On the Chesapeake Bay
    Yes as described by FLX109, just pull them and twist back and forth until they come off. I got new clips that were nicer than factory clips from Auto Zone. They are in the aisle where the nuts/bolts are hanging on the rack or ask an employee. You can match them up easily by looking at them, sorry i dont have the packages anymore!!! Good luck :)
  4. KERS-VPR
    KERS-VPR Viper Owner
    267
    Sep 10, 2002
    PEP BOYS has them also packaged in a set of 3 for about $2-$3 same clip.
  5. Bad_Byte
    947
    Jan 16, 2002
    Riverside, Ca.
    Very cool, thanks everyone.
  6. thebigsnake
    thebigsnake Viper Owner
    65
    669
    Dec 3, 2003
    Montreal, Canada
    They break when removed. The cost for a box of 25 new ones is negligable. Dodge parts deparment has it.
  7. AviP
    AviP Viper Owner
    2,274
    Nov 7, 2000
    New Canaan, CT
    Check with your local auto body parts supplier from the yellow pages. They generally sell them in packs of 10 or 20 and will work out much cheaper. Take one out for comparison purposes.
Share This Page
