Hurst Shifter
JoeB
Danville, CA, USA
This weekend I had several problems shifting into 5 and back into 4th gear. After several times getting stuck in nuetral I decided to take apart the shifter mechanism. I found several little rocks and a piece of rubber. They just happen to be on the right side of the shifter. The plastic inside is now scratched and worn so I have still having problems shifting but not getting stuck and not as bad, which I believe was caused by the rocks and the piece of rubber. All the grease had dirt in it.
Just a heads up--I am calling Hurst about a boot. The top of the shifter is not protected.
Its pretty easy to service the shifter and change out the grease. You might be surprised by what you find in there
Joe B
Viper123456
