Installing Gen 4 headers - how to take out the passenger side headers ?
ACRsnake
Cairo ,Egypt
how to take the passenger side headers out ? I lifted the engine max lift and still cannot snake it out ?? any tips ??
F8L SNK
Spring, TX.
Only lift the passenger side of the motor. If you lift the whole motor it doesn't work. Leave the engine mount attached on the driver side and it will help
A
ACRsnake
Cairo ,Egypt
thats what i did , but i didn't leave the driver side attached . will try that tomorrow .
Do i have to take out the wipers cowl ?
F8L SNK
Spring, TX.
No you don't have to but I do anyway since it is so easy. It really helps when you get to the back spark plugs and the back tubes on the headers. That is always the first thing I remove.
By leaving the driver side loose you went up even with the motor, it actually helps to pull the motor sideways to get the header out and back in. Good luck
TrackAire
Vacaville, California
Removing the wiper cowl and the overflow bottle and hose made all the difference. I'm sure the experts might chime in. Good luck and enjoy the ride.
Cheers,
George
A
ACRsnake
Cairo ,Egypt
got out that POS header ....... i was loosing my mind ..would not defo do it again .... what a nightmare !!!
had to get out the valve covers ,cut the heat tin thingy with my dremel .....
SKY1960
