MAMBA
I'm thinking of installing a set of Belanger headers on my 95 RT/10 myself. I've done a considerable amount of automotive mechanical work so I'm confident I can do it. I just have a few questions for those that have already done it.
01. Are the heat shields just held in place by the nuts on the top exhaust manifold bolts?
02. What is the easiest way to get to the bottom exhaust manifold bolts?
03. Should I disconnect the exhaust and manifold joint first?
04. What will I need to connect the header exhaust flange to the stock exhaust flange or is there another piece required to replace the stock flanged flex joint?
04. Finally, are there any secrets I should know to make it easier besides patience, patience, patience?
Thanks for the help.
