Instructions for getting access to the taillight bulbs
vipertom7
West Chester, Pennsylvania
I need to get access behind my taillights to replace the bulbs, but I'm not sure what needs to be taken out from the trunk interior in order to get to them. Could someone possibly point me in the direction of a tutorial for taking apart your trunk interior in order to be able to change the bulbs? Thank you.
ViperJohn
Maryland
There are three rubber grommets one each side. Remove the grommet and this will give you access to the 7/16 nut. Loosen each and remove.
Manual says to remove entire tail light assembly, but many have been able to use first method.
Good luck.
V
vipertom7
As for the actual interior of the trunk, how do I go about removing that in order to get to the rubber grommets? Does it just pull away from the body of the trunk or do I need to unscrew something? I'm referring to the interior lining that has the speaker grills attached. How do I remove that? Thank you.
potterb4
