Is there a 3 volt source in the car?
ViperDad
I'd like to run power to the Snake Oyl cruise control instead of the battery that came with the control. I hear that the battery needs replacing every few months.
Sonoman
Sonoma Cownty
You could get a 3V DC regulator that is hooked up to a 12V input, since there are plenty of 12V switched or unswitched wires in the car. However, would running another wire to the cruise control be conspicuous? There would also be the issue of wiring up the IC voltage regulator if you are not an "electronics" type of guy. It is cheap and easy to do if you are, but otherwise, not recommended.
Viktimize
Edmonton, Alberta
I would just tap a switched 12v source in your fuse box, and use some resistors to drop it down to 3v. Pretty sure you won't find a 3 volt source anywhere.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
OK - I'll be the first to say it - Buy a few replacement batteries and put them in the center console - problem solved.
Is winter here already :dunno:?
AZTVR
Chandler AZ
steve911
Cottage Grove, Wi.
I have that cruise in my '04 and I just this past spring changed out the battery in the control module for the first time. Its been in the car for over 4 years.
V
ViperDad
Well, that puts a different perspective..4 years is not inconvenient, so the issue is dead. Thanks all
xeng yang
