on my 99 R/T when the car finally warms up for the first 10 minutes of driving when you let off the gas as the rpms drop it gets stuck at 1 and 1/2 almost every time you let off the gas, only for the first 1 minutes then its perfect
any ideas?
Don't listen to those guys. SHEEZZZ!!!!!!
The problem is simple, and the fix is simple. Go to AutoZone or a car parts place, and get a header fuse.
What happens is when a header fuse starts to go out, it will send electric shorts/spikes to other electronic sensors(rpm) and will spike it/cause it to hang. If it only is doing it for the first 10 minutes, it's probably contracting when cold(metal expansion/contracton due to temperature) but it's nit ready to pop/break to fully go out.
I got my replacement at AutoZone for pocket change. Upgrade and use a higher amperage fuse(20amp). If you haven't figured out which side it it, replace both, or to be on the safeside I would do both.
Glad to help you.
