it's time to change my tranny and diff fluid. what should I use?
Steve Miehe
Cincinnati, OH. USA
Re: it\'s time to change my tranny and diff fluid. what should I use?
Am in complete agreement with Tony. Get the factory fluids. The tranny and differential fluid are price (one is about $16.50 per quart and the other about $21.00 per quart). No substitute for factory fluids, especially should there be any type warranty question.
Tom Shapiro
Just changed my differential fluid today. Make sure you get the limited slip additive. Here are the Mopar part numbers.
You'll need about 1 1/2 quarts of the diff fluid and 1 bottle of the additive. Here's my cost.
diff fluid- #4874469 $14.68 x 2= $29.16
additive- #4318060ab $ 4.13 x 1= 4.13
You'll have to **** the old fluid out with a hand or electric pump. It's thick and it stinks. Good luck!
Qualitywires.com
Louisville, KY
What oils and brand should I use on my 1998? Redline...do they make diff fluid? What about tranny? Or should I stick to stock Mopar?
BlackACR
Rowlett,Tx
Stick with the Mopar recommended fill. I will save you a lot of time. I asked the same questions about a month ago. Mopar fluid will not void any kind of warranty you have either.
tbone96
