K&N HP-2010 Oil Filter & Lifter Question
Skeeter Blanton
Valdosta, Ga.
Has anyone used the K&N HP-2010 oil filter on their 2008? Their tech dept. states it was only tested on an 09 and can not recommend it for the 2008.....Aren't they the same? Also has anyone with an 08 had a lifter problem?..Thanks for your time....
01sapphirebob
"OIHO"
There has been a lot of talk about the oil filters lately. From all that I have read the MOPAR filter is the best filter to use. I have both MOPAR filters on my '01 and '08 vipers. There are different part numbers so make sure you order the right filter. You can pick them up from most of the site supporting vendors like JonB@ partsrack and Woodhouse (ask for Mark).
2 questions were asked above:
Answer #1 Yes, the same filter for 2008, 2009,and 2010 Vipers. Mopar part number 05038041AA
Answer #2 No, at least not yet on our 2008 with 1500 miles on odomerter.
daffyduck
Mine has a slight lifter noise when it first starts up.What lifter problems have you specifically had .
Skeeter Blanton
Valdosta, Ga.
I have a loud "tick" that comes and goes but has not been identified as a lifter problem as yet......It comes out of the right side and can be very pronounced and then fade away completely...It can happen on start up and when the engine is warmed up.........I have no viper techs close to me and would welcome any opinions......Thanks for your time
userSRTbro_
