Key Fob programming instructions
Viperdriver
Horn Chirp Disable:
1. Press LOCK button 4 seconds.
2. Within 6 seconds with the LOCK button still depressed, depress UNLUCK button.
3. Repeat to enable.
Optical Flash Disable:
1. Press LOCK botton for 4 seconds.
2. Within 10 seconds with LOCK button still depressed press TRUNK button.
Door Unlock Sequence (unlock all doors at once):
1. Press and hold the UNLOCK button for 4 seconds.
2. Within 10 seconds with the UNLOCK button still depressed, depress the LOCK button.
3. Repeat to return to driver door first.
Viperdriver
To program a fob:
1. Using programmed fob unlock car, disarm alarm, insert key into switch and turn switch to run position but do not start car.
2. On programmed fob press and hold UNLOCK button for 5 to 10 seconds. While still holding the UNLOCK button and before 10 seconds press the PANIC button and release both. A single chime will sound.
3. Within 30 seconds of the chime press and release the LOCK and UNLOCK buttons on the second fob at the same time. Then press and release any button on that fob. A chime will sound to indicate successful programming. Turn ignition switch off.
Up to 4 fobs can be programmed for 1 car.
Viper IV
East Bay Area, Calif
Thanks Curtis, saved me from those "looks" my wife gives me every time she goes to get into the car. Her side was always locked.
Bob
xeng yang
