Leak? Anything to be concerned about?
tattooed
KC
While looking under the hood, I noticed some grime/oil/residue on the lower right side of the engine bay. It's a 2010 ACR w/ 13k miles. Oil pressure is fine, oil level is fine, and I've never seen a drop of oil (or any other fluid) on the ground.
Is this anything to be concerned about?
Small pic:
Large (3264x1836) version of pic: http://www.kcsr.org/kafir/leaklg.jpg
Allan
La Junta Colorado 81050
Oil cooler line seep is common. :(
Fix with new lines and fittings at both ends. :D
You can see parts of the oil lines in the pic, and they appear to be the source.
I've had to replace mine twice so far. -2006 with 56,000 miles.
Not a big problem to address, just consider it a maintenance thing.
Oil / tranny lines like that leak on other cars. Viper isn't any different in that respect.
The gen III power steering line issue on the other hand, is something that totally *****. :crazy2:
T
tattooed
KC
Thanks for the input guys. Very much appreciated. )
T
tattooed
KC
Viper is at the dealer now being repaired. Car is still under the original 3/36 warranty, and I assume this would be covered.
T
tattooed
KC
Update: dealer confirmed it was the oil cooler lines. Will take 3-4 days to get replacements. Should have the car back by Fr or Sa.
TRACKDAY
Woodbridge, VA
I had a similar leak / seep on my 09 ACR.
I ordered the steel braided lines the other day from Viper Specialty and will have them installed in the near future.
.....definitely a must for track use.
Qdog
