Looking for a fuel pump relay
plumcrazy
ALL OVER
Jim, what kinda problems ya having ?
not that i can help, just wanna know in case i end up with the same problems
Joseph Dell
Atlanta, GA 30338
A standard chrysler 30amp relay (standard part at auto-zone) will do the trick. Just go pick one up and wire it in.
good luck!
JD
J
Jim Wilson
Chandler, AZ, USA
ahh... could be where the TAC signal is coming from.
Yeah, that's what I originally thought. According to the manual, the tach signal is pin #24 20GY/LB. For the heck of it, I tried the crank sensor (thinking it might have the same pulse as the tach) but no luck.
Man I hate electrical crap! :mad:
Joseph Dell
Atlanta, GA 30338
I am not so sure about your tach source... You can get a tach signal from the coil packs or from the lead labeled 'tach' but it isn't the pin you specified... at least on the 99.
This could be related...
xeng yang
