vipah
Anyone have suggestions on which jack is best for use wiht a 4 post lift? I assume it will be a bottle jack.
Thanks in advance.
Thanks in advance.
The oem scissor jack is a good call. You can also use two scissor jacks to lift the whole front off the deck. You can lift one corner in the rear with the scissor jack, however, if you try to lift the entire rear off the deck the car will inch forward (no matter how well you block it)and the scissor jacks become unstable. To take the whole rear end up I lift one side and lower it on to a wood block on my jack plate. You can then do the same to the other side.
Instead of taking the car all the way up and bending your back/neck to inspect or work, you might want to try using a chair type creeper with a back rest and find a workable height at partial lift. With the back suppoert you can angle your body into a comfortable working position.
