- Joined
- May 1, 2004
- Posts
- 3,471
- Reaction score
- 2
Fadi,
Based upon what you say in your first post, the only place 3.07's would be advantageous to you would be in the gas mileage department, and I really don't think most Viper owners care much about that. The 3.55's will be a great mod for you. The car is much more "drive-able" and fun with stock power.
I ran 3.55s in my SRT-10 when it was stock and lightly modded. Great fun. When I went to the Paxton, heads, etc. - 750 rwhp - I went back to the 3.07's and was very happy with the change.
I raced in and won the 1/2 mile drags last spring at a top speed of 150 from a stop at 6500 feet elevation. I'm planning to run in the 1 mile drags at the Nevada Open Road Challenge this year with the new engine and 3.07's. My goal this year is to get to 190 mph from a dead stop in a mile at 6500 feet above sea level. My rwhp should now be about 900. 3.55's wouldn't work as well for me in this race as 3.07's with stock tire height, 27.4 inches.
As GR8 ASP says, you should gear the car for what you intend to use it for.
I also have a 2001 GTS with a WCV 650 package that makes 555 rwhp / 581 rwtq. I am changing to 3.45's with 18-inch tires. This works really well in this car at this power level driven on the street. I am keeping the 3.07 gear set and will use that set on a road course if the road course warrants it.
As far as lower gears being harder to drive on a road course, yes, they can be as Fred says above. If wheel spin becomes a problem with the lower gears, you can always go up one gear with the trans, i.e. exit the turn in 4th instead of third, etc. This approach really helps with any Viper with lower gears on a road course.
Good luck and enjoy your car.
Dan
Dan
