lowering springs: looking for before and after pics
TAILWAG
Does anyone have any photos of a car WITHOUT lowering springs and antoher picture of the SAME car AFTER installation? The gap on my 98 GTS is getting the best of me...I want to see how much a set of lowering springs can actually lower the car and see if I would be happy with it.
Thanks!!
jc411
before
after
spring caps also...
T
TAILWAG
Do a search there are tons of threads regarding this question.
:usa:
Thanks...I tried searching some but I would always come up with different cars/different wheels...I was trying to find one that had kept same wheels with a before and after...came up with nothing... :(
Dimitrios
Queens, New York
ive done both and i think youll be happy with just the springs..the lower you go the rougher the ride plus youll be scraping that front lip under the bumper.
T
TAILWAG
Thanks for the feedback...that is probably the main reason why I have kept myself from pulling the plug. The rougher ride does not bug me too much...but scraping everywhere would definitely keep me from doing it.
What exactly do the "caps" do anyway?
Thanks for the feedback.........
Spring Caps will lower all 4 corners by .7" with only a $179 cost (plus aligment) and a LOT less labor. In a nutshell: the OE spring caps above the spring are "thicker" by .7" than our billet aluminum replacements. The RIDE stays the same but the lower CG makes the handling a bit quicker-responsive.
Just jack up the car, compress the spring, rotate/slide out the old cap, slip in the new. Release the spring. Repeat 3 more times. Realign. DONE !
T
TAILWAG
Thanks...I don't know if the .7" will be enough for my 4X4...how much do the springs actually lower it?
ACELLR8
Harrisburg, PA
I measured my gap in the front before and after and the drop was right on 1.25 inches. I know someone who did caps alone and you really can not tell it was lowered. Go with springs and adjust the stock Konis Dampner stiffer, it will give ya a stiffer ride too.
R
RTED
Guest
It seems the gap above the rear tire is more evident than the front. Can you do the rear only?:dunno:
T
TAILWAG
:drive:
Thanks man...this might do the trick...what brand of springs did you get and how much where they?
jc411
spring caps do NOT lower .7" that is total BS. more like .25"
ACELLR8
Harrisburg, PA
:drive:
I used Intrax springs for my car because Eibach's are no longer available for Gen I's. Cost was $180. I would agree Eibach's would be a great choice for your car and cost around $280. Make sure when you put the Eibachs on you adjust the Dampners on the stock Koni's. I was told to push the shock all the way in with the rubber stop off, turn the shock clockwise until it stops, then turn out 3 half turns.
Ed
T
TAILWAG
thanks everyone for their feedback and sharing pics. Now I have to decide how long I am going to keep this car and if doing a drop is going to make me keep it longer...or if I can find a dealer that can give me $ 35k on trade, I might just make a jump on a new ACR...
ViperTony
I've wondered about the actual difference. I've read .5", .7", .625" in the classifieds, etc. Which is it on stock springs?
KenH
Portland, OR, USA
Have any of you that have slammed your Vipers had to put them on a flatbed truck yet? I have loaded a couple of Vipers that were stock or lowered a bit and they were tough enough. I can't even imagine how you would get a slammed Viper up on the truck without damaging the front end.
PS78
UK
Same as Baz above - just caps. Thought i'd try them first before considering springs and despite being just .5" drop, it's made enough difference. Touched the deck a few times at stock height, now i have to be far more careful... don't need to go lower.
before
after
viper k
my 1996 gts had 17" i went with 05 five spoke 18" on front 19" on back looks like i lower it
rlamorte
