Laurie --
Your not alone when it comes to difficulty reaching the pedals. Here's a solution to your problem. You can knockout the rivets that limit the drivers seat travel. Once you remove the rivets, the driver seat will have two more inches of forward travel. This will provide you with more than enough room to reach the pedals. You do need to remove the seat to remove the rivets.
Also, the lumbar bulbs are interchangeable between both seats. It sounds like the valve is bad in your lumbar pump. If your lumbar support (or bladder bag) leaks after a few days, you can check it by fully pumping up the lumbar and spraying a light mist of soapy water on the valve area. If the leak is not present there, you will have to remove the seat to check the bladder bag for leaks.
Good Luck
Doug Levin/Doug Levin Motorsports
