Viper Fever
I have been having some issues with my 2002 GTS Roe supercharged Viper. Right now the code is a ( po 302 cylinder 2 misfire ) I just bought
new wires from ABs wires , Changed plugs I even changed the computer . The only thing I haven't done is the coil packs . Is there anything
else I should check. My Viper has 15,000 miles on it when you drive you can definitely feel that it is not firing on all the cylinders. The
number 2 spark plug when you pull it out is wet and unfired. Thanks for the help.
