Momo Steering Wheel
gtsacrrox
Arvada, Co.
I have a 2001 ACR, if I replace the factory steering wheel with a Momo and pull the Airbag fuse will I still get a light? I can clear codes but I just do not want to do that every time I fire the car up.
CWhiteRun
Has Left the Room!
Dothan, AL
I'm about 99% positive that you will get a light. Easiest thing to do is pull the fuse and yank the bulb out of the cluster.
Nadine UK GTS
Bath, Somerset, UK
I've installed several Sparco and Momo steering wheels with a quick release (and buttons on the spokes for the horn). It will set a light, fuse or no fuse, you have to remove the push-in bulb from the back of the cluster. Or you can make up a circuit with matched resistor to the air bag.
trydh
Sweden
I have put in a MOMO in my -99 and yes the light is turned on!
But there is a solution to that problem, put in a resistor in the plug for the airbag and the problem is solved !
I can´t remember what resistens it was on the resistor but it´s no big deal to find out.
I will try to help you out with that one if you like !?
Missjazzyfitness
