Mopar oil filter or Mobil 1?
AJT
Houston, TX , USA
Its been a while since I changed my oil, trying to remember if the Mopar oil filter is recommended or the Mobil 1? Thanks, Andy
AJT
AJT
Houston, TX , USA
Thanks, DLM did the last oil change. Just bought some race ramps & extensions to help with the process.
AJT
AJT
Houston, TX , USA
Hey Paul! My new granddaughter has taken up a lot of free time the past year or 2. I have renewed my membership so hopefully I can get back on the Houston Emailing list. Houston is perfect Viper weather right now! Good to see a familiar face.
rpm9000
Texas City, Tx.
The Houston club is having a dyno day on November 10th. It is free to paying members. I plan on being there. Come on out if you can. If you plan on coming you will need to RSVP. I can forward the info to you if you are interested.
brentsGTS
I use the mopar filter with mobil 1 0w-40 motor oil. Thats what my viper tech said.
AJT
AJT
Houston, TX , USA
The engine is not stock, built by Doug L. (DLM). Paxton SC, Greg Good heads, cam, pistons, balanced, billet crank, etc.... It needs the heavier weight oil.
ttamez
I have a paxton too, is the heavier weight oil so it can keep higher pressure due to extra heat from being FI? last time i changed the oil i used the weight the service manual recommended.
BTW i will be at the dyno day as well.
Missjazzyfitness
