Mopar Performance T&D Roller Rockers On Sale
BLWNV10
For a limited time I am selling Mopar Performance T&D Roller Rockers for $1,050.00. Mopar Performance retail is $1,717.00. These are all new, and in a sealed box. P5007049 is the Mopar Performance number.
Thanks,
Alan
www.AlansPerformance.com
B
BLWNV10
I currently have One remaining set of the T&D Roller Rockers at the sale price above. $1,050 plus S&H. I am trying to get more though.
Thanks,
Alan:)
MoparMan
Las Vegas, NV
I thought you had to measure and order custom length pushrods for the Mopar 1.7's unless you mill the rocker stands on the heads. Is that true or do you know what length pushrods would work for the 1.7 RRs on a 2000 engine?
ViperRichRT10
Suwanee, GA
You better measure your pushrods if you change rockers!!!!!!
2002_Viper_GTS_ACR
Charlotte, North Carolina
Accourding to the Mopar performance catalog it states "uses stock pushrods".
FYI. Not true. I have put 2 sets on my car (Sold a head package with a set and then bought a second set for my stocker heads when i put them back on), and 1 set on a buddies car. You need new pushrods to get the geometry right.
Jon
Joseph Dell
Atlanta, GA 30338
The mopars are the exact same (sans color) as the T&Ds. And the stock pushrods may or may not work. in every case that i've done this swap (about 14 so far) we have needed new pusrods. in one case, we _could_ have re-used the stock pushrods if we shimmed the pedestal stand. but that was going to bring on the wrong valvetrain geometry. so we got new pushrods.
every car is a little bit different, unfortunately.
JD
B
BLWNV10
Keep in mind if your not in a hurry, buy the RR's first and set up one side temporarily and measure before getting a push rod checker. You may be where you need to be if you want to use the stock ones.
As said above, you are setting up the geometry.
The stock push rods also have a thinner wall than what you would order aftermarket. If the thinner wall flexes you lose a little lift.
Alan
LETHAL GTS
Winnipeg, MB
Jon
Yes I was mistaken. I forget where I read that, but after double checking, it wasn't the Mopar perf cat.
Sorry for any confusion.
2002_Viper_GTS_ACR
Jon
Cool deal, thanks for being man enough to admit your mistake. I just want to avoid miss information, it benefits the viper family as a whole if we have our information right.
Thanks,
Jon
xeng yang
