The main thing I like about the KB over the MSD is the way it gets it's signal to see boost.
The MSD has a ****** for a boost hose (boost reference) on the box, this means the box really needs to be mounted up front.....the common place is where the vec2/3 is mounted. Crowded there ? Is that a hot location ? Look like a race car instead of a street car ? You have plenty of room....ok, how far are you running the wire to the pump ? Probably alllll the way back to the rear of the car. So you just installed this to get lots of voltage to the pump and then you run 12' to 15' of wire to the rear
The KB has a boost switch that can run from a very short boost hose (boost reference) Mine is around 10" (yes, I'm bragging
) From this switch two wires run to the rear of the car where the BAP is mounted. I mount it upside down above and just behind the factory amp. Can't see it with out looking. The two wires from the boost switch to the rear aren't carrying a lot of current....it's only to tell the BAP that the boost has went above 3psi.
What does this mean ? The wire from my BAP to the fuel pump is short like they should be. I have seen others have to put larger fuses in the supply voltage line to the MSD because they were blowing fuses ? Makes me wonder, is it working too hard ?
The KB keeps a constant voltage:
Maintains constant output voltage to pump within 1% from 10 to 12.5 battery voltage.
Does the MSD do this ? I can't find where it states it does.
What does this mean ? When you turn your lights on, stereo/amp on does your voltage vary ? They say it will. Is the KB different in this regard compared to the MSD....dunno ??
Once I pass 3psi my voltage to the pump goes up and stays constant. Best I can tell the MSD keeps climbing with the boost....maybe not to a higher voltage but starts lower at 5psi then climbs. Better ? Worse ? I don't know.
After I put two in tank pumps I didn't really need (or want) extra voltage to the pumps. I left the KB in line because I still wanted a constant voltage no matter what accessories were on or battery condition or alternator output. Does it help ? I don't know, but I feel better.
Don't get me wrong, the MSD is probably in 97% of Roe cars that have a BAP because that is what Sean sells. It will work fine.
This leads me to another point
What is the final goal with the BAP ? TT ?? S/C at 600+ whp ? Would it be better to go ahead and drop a few pumps in the tank now and use the BAP $$$ towards that ? Has everyone seen my pictures of the 1/8" orifice (restriction) that the fuel has to flow through six inches after it leaves the pump ? Heck, do away with that restriction and no one should need a BAP. I'm still amazed the cars even run WOT through the stock fuel restrictions
