NE1 know the CFM of stock GEN 1 Throttle bodies?
SEASNAKE
Wilmington, NC USA
I had a set of stock throttle bodies that I personally opened up, then had a machine shop clean up. I never tested these stock and was wondering what the stock ones actually flowed.
The numbers I got back from the shop were 496 (mine) and 516 (cleaned). I seem to remember the stock ones being 375.
It was also relayed to me that they were 82% at 28in (mine) and 85% at 28in (cleaned). What exactly are these percentages anyway?
NCVCA
Raleigh, NC USA
Flow is the volume of air, I'm not sure about the percentages, but I assume higher is better.
Does anyone know the stock diameter of a GEN I TB? Obviously, I have searched the forum.
Thanks,
Jeff
SEASNAKE
Wilmington, NC USA
Man, you are digging up some old stuff here. The stock Gen 1 throttle bodies are about 53mm wide where they taper down behind the butterfly.
NCVCA
Raleigh, NC USA
So when SCCA requires a 55MM restrictor plate they are doing nothing...
What are Gen II diameters? BUELLER?! BUELLER?!?!
