Need headlight switch plus 6" of factory wire harness
Are you looking for the mechanical switch and/or the knob? The headlamp switch lists for $63.75 from Mopar, while the knob lists for $57.80.
https://www.viperpartsofamerica.com...996-2002-dodge-viper-headlamp-switch-04763135
The wire harness is a little harder to pin down, as Mopar shows the headlamp to dash wiring (expensive, out of stock, and discontinued), and the wiring bundle itself for the dash (also expensive). Your best bet if you want that single pigtail is probably to contact one of the Viper dismantlers like Paul Scharf.
A
A99SilverACR
MI
I am looking for the switch itself and the pigtail, thankyou for your help i am glad you took the time to answer i'll call PAUL
Sounds good. We have the switch available (brand new), but the pigtail is definitely something you will want from one of the dismantlers.
jpolen21
