Need help w/ HREs
grayman
Prince Frederick, MD USA
Got a set of HRE 543s, 19". Were on a GTS. Trying to put on my SRT. Fronts are fine, rears are the problem. They clear the calipers fine but the e-brake connection cable has about a 1mm interference. Can this be articulated to not interfere...looks like some allen connections that might work but not sure. Or do I need some sort of ebrake relocation??? Any info appreciated.
G
grayman
After you machined bracket, how much clearance did you have between it and the rim? Wouldnt think you would need much but the stock rims have at least 1/4" of clearance and I would be unable to machine the bracket that much. There looks to only be maybe 1/8" or so that I could machine. That would be enough but would leave only about that much clearance. Am I confusing enough???
Viper IV
East Bay Area, Calif
I'm running 18" HRE'S in the rear with the machine work. All you need to do is clear the e-brake cable. No rerouting of the cable to an uncomfortable position just to make it fit.
Rob
Viper IV
Grayman, The bracket that the e-brake cable comes out of. I sent you a picture. Sorry I don't know how to post it.
Fred, yes I needed a spacer to help the wheel clear the brake caliper also.
Saratoga,CA
My fix was to sell the HRE's and bought BBS's. Had zero problems with the BBS's.
I called HRE (purchased wheels at VOI in LV in 99.) to get a corrective action as they told me they would fit my ACR. They said they would get back to me, never happened! No big deal! I vote with my $$ they will never get another cent from me.
Qdog
