Need help with Console fix????
got one
Castle Rock
Anyone have any bright ideas on how to fix a Gen 1 console (around shifter) from popping up? Mine keeps popping up and Velcro doesn't seem to do the trick anymore, I am debating on screwing into it with Viper headed screws if I can't fix it any other way.
IEATVETS
Cottage Grove, Wis.
Here is a picture where you can see the screws, one on each corner.
kARLUG
las vegas, nv
I tried velcro and couldn't get it to stay down. I went with 2 screws. I purchased black plastic screw caps at Home Depot and they actually look pretty good. No more console problems.
plumcrazy
ALL OVER
I've been thinking of doing this exact fix. im gonna do it this week i think.
thanx for the push.
JoeB
Danville, CA, USA
Just a thought.
I would use clear silicon as a glue. Put enough to bond both pieces together,it should not take too much. It should hold the console down, and if you have to pull it up you always can. Use silicon and put some weight on it for a couple of hours and your set.
Joe B
tbone96
