need part #
luc
Paso Robles CA
To adjust ride height (00 GTS) you can get either a factory shim that go between the spring and cap or you can get a reduced height cap.
neeed part # for both
L
luc
Paso Robles CA
Are you talking about lowering caps like you can get at Parts Rack or Roe Racing or many other places?
My Viper, like many other seat lower on the rear driver side (about 1/4").
I changed the shock/spring from side to side with no change so i want to jack up the driver side by putting a shim/spacer between the coil and cap.
The shop manual show both the shim and cap but I can't find ant parts # for it
The real ? is why so many Vipers have this issue?
Missjazzyfitness
